Home » Audio » Speaker » 1:1 throat area
Re: 1:1 throat area [message #19117 is a reply to message #19115] Thu, 22 February 2007 11:28 Go to previous messageGo to previous message
DMoore is currently offline  DMoore
That example would be a multiple-flare horn or a "rubber throat". Not typical of a "straight" horn, though. Better used in a longer folded type bass horn to reduce throat impedance.
On the other hand, though, the 1978 EV midrange horn (Keele) US patent # 4,071,112 has 3 separate flare rates for purposes of bandwidth and coverage pattern. So there is no real limitation as to what you can do if you can achieve a balance of all the variables involved to arrive at your particular goals.
DM
Previous Topic: comb filter distorsion
Next Topic: Adding Tweeter to Full Range Driver
Current Time: Thu Nov 12 12:17:54 CST 2026
