Home » Audio » Speaker » 1:1 throat area
Re: 1:1 throat area [message #19115 is a reply to message #19113] Thu, 22 February 2007 10:04 Go to previous messageGo to previous message
Generally, the closer to the diaphragm, the more impact flare changes make. I would not want the throat expansion rate to be greater than the rest of the flare, unless the area where this happened was small in relation to wavelength through the bandwidth of the device. On the other hand, there may be cases where this kind of shape smooths the response curve or does something otherwise beneficial. I'd sure check it with Hornresp to see what effect that short section at the throat entrance will have.
Previous Topic: comb filter distorsion
Next Topic: Adding Tweeter to Full Range Driver
Current Time: Thu Nov 12 12:17:47 CST 2026
