Home » Audio » Speaker » 1:1 throat area
Re: 1:1 throat area [message #19113 is a reply to message #19112] Wed, 21 February 2007 22:24 Go to previous messageGo to previous message
Cuppa Joe is currently offline  Cuppa Joe
I was knocking around some ideas for a low-compression throat section which would mount over the driver from the front of the horn. I imagine it to be more of a smoothing transitional guide intended to reduce reflections of higher frequencies. Maybe it will cover only the driver's frame, maybe it will encompass the surround, as well. Is there any real harm if the throat expansion is a wider angle than that of the horn walls?
Previous Topic: comb filter distorsion
Next Topic: Adding Tweeter to Full Range Driver
Current Time: Thu Nov 12 12:17:49 CST 2026
