Home » Audio » Speaker » ?Horn Questions?
Re: Compresison ratio and front chamber size [message #19101 is a reply to message #19100] Wed, 14 February 2007 21:07 Go to previous messageGo to previous message
Cuppa Joe is currently offline  Cuppa Joe
I haven't run any HornResp scenarios for the "throatless" horn yet. (Sounds a little like the "Headless Horseman"!) I was hoping that maybe a narrow enough coverage angle might make up for some of the lost efficiency. In this case, as the wavelength becomes longer than the driver's diameter, does the efficiency increase for those frequencies? That is, would the lower frequencies see a higher compression ratio than those frequencies shorter than the diameter? Or, does a given throat geometry determine an overall compression ratio, regardless of frequency (within the passband, of course)? I have daydreamed about designing a simple throat section for this horn that could mount in FRONT of the driver...dreaming...where to start...!
Has anyone else (besides Peavey and Meyer Sound) tried this idea?
Previous Topic: Room treatments and OB
Next Topic: What's Vintage Sound?
Current Time: Sat Oct 17 21:06:57 CDT 2026
