Home » Audio » Speaker » ?Horn Questions?
Re: Pattern control and mouth size [message #19097 is a reply to message #19096] Sun, 11 February 2007 13:40 Go to previous messageGo to previous message
I don't think center-to-center spacing will be as much an issue when splayed, either vertically or horizontally. In the range where each of the horns have pattern control, overlapping fields would be more of an issue. The tight pack array, for example, has drivers physically close, with the apex of adjacent horns right next to one another. The wall angles are splayed, and adjacent walls nearly touch. This makes the pair of horns act similarly to a single radial sectional horn.
In the case of crossover between horns that cover different bands, the region of interest is the overlap region. If the spacing between sound sources is within 1/4λ through the overlap region, then the two sources will act as a single sound source.
In any event, if sound sources are too numerous to allow for tight pack spacing, then the next choice is dense interference. There are merits in this approach, as it smooths the sound field even though spacing is further than 1/4λ, and often times further than 1λ. Another thing that results from this approach is it tends to smooth out the nulls that result from reflections in the environment.
Previous Topic: ?Horn Questions?
Next Topic: North Creek 13W Driver
Current Time: Wed Oct 28 08:53:22 CDT 2026
