Home » Audio » Speaker » Listening distance from speaker
Re: It depends... [message #19054 is a reply to message #19052] Wed, 31 January 2007 15:19 Go to previous messageGo to previous message
Well I may be incorrect, but my (admittedly limited) experience suggests that hearing high frequencies come from the mid/woofer cone is the primary distraction, and the steeper the slope the less high frequencies will be coming from the mid/woof. Also, when a steep slope is used the crossover frequency can usually be lower because the tweeter is better protected.
As an example from another frequency realm, subwoofers with a steep-slope upper cut-off do a better job of "disappearing" than subwoofers with a gentle-slope upper cut-off, again because if we can hear the upper frequencies (even at reduced volume) we can better locate the sound source. I recently had the chance to compare plate amps with 12 dB/octave and 24 dB/octave high pass filters, and the latter enabled me to cross over almost an octave higher before the subwoofer's location could be detected.
Duke
Previous Topic: Word document for cutting flange of Neo Tweeters
Next Topic: Fostex FE126e
Current Time: Fri Sep 25 13:33:29 CDT 2026
