Home » Audio » Speaker » Speakerlab K Horn
Re: Speakerlab K Horn [message #19037 is a reply to message #19034] Fri, 05 January 2007 17:35 Go to previous messageGo to previous message
DMoore is currently offline  DMoore
Well, Speakerlab was wrong. Not you. Just don't believe everything that they publish!
Clearly the 100Hz reference is a direct and mistaken ripoff from the original 1945 Klipschorn patent document, which was concerned with a smaller version featuring a single 12" field coil driver which DID indeed use a 100Hz flare rate at the throat. So much for copying the at-the-time-and-still-current-flavor of the larger 15" driver version of the Klipschorn and not knowing why it's the way it is...
However, the 1970's Speakerlab "K" used the familiar 15" driver and the normal 50Hz throat expansion rate, as indicated in the Speakerlab "K" plans. Anyone with a ruler can figure it out. Wavelength/18.1 = exponential area doubling length, and that isn't going to amount to 100Hz (that would double its area every 8 inches (approx) of linear travel)!
The throat area cross-section doubles, according to the plans, at at approx. 16 inches, measured center of channel, which would be 50 Hz, thereabouts.
DM
Previous Topic: so I built these lines with a single tweeter
Next Topic: Pick the right mid/woofer
Current Time: Wed Oct 21 17:22:52 CDT 2026
