Home » Audio » Speaker » hornworks
Re: hornworks [message #19036 is a reply to message #19035] Wed, 03 January 2007 10:44 Go to previous messageGo to previous message
::What would be the effects of adding DynaMat or similiar material to the sound path of a horn(front chamber and horn area)?
Attenuated hi frequencies.
::And what is the effect or purpose of the front chamber and what would be the effect of eliminating it? In other words, what purpose does it serve?
It acts a a low pass filter. So eliminating it would let higher freq. pass.
::I know it will increase pressure, but what is the advantage of that? And the disadvantage?
Horn gain-over a narrower bandwidth, disadvantage-less efficent horn.
::Would you loose efficiency, but gain bandwidth by removing it?
Yes.
HTH
Bill W.
Previous Topic: single driver
Next Topic: Semi out of place question.
Current Time: Sun Nov 29 12:33:15 CST 2026
