Home » Audio » Speaker » Really Front-Loaded
Re: Really Front-Loaded [message #18931 is a reply to message #18929] Sun, 17 September 2006 10:21 Go to previous messageGo to previous message
PointSource is currently offline  PointSource
I should clarify: I meant lower HF cutoff due to beaming (previous post).
Then, in contrast, the narrower the horizontal coverage, the higher the HF cutoff (taking cone breakup modes into account). Am I on the right track? And, I'm assuming that pairs of like drivers sharing the same horn would be subject to the usual coupling rules when baffle-mounted, right?
I'm trying to be careful with making intuitive assumptions about how a cone driver would work in a horn as opposed to a simple 4th or 2nd order box, hence all the Q's.
Previous Topic: Say Charlie; Have you changed your speaker set-up ?
Next Topic: New single driver
Current Time: Sat Oct 17 12:04:40 CDT 2026
