Home » Audio » Speaker » Really Front-Loaded
Re: Really Front-Loaded [message #18923 is a reply to message #18913] Fri, 15 September 2006 21:42 Go to previous messageGo to previous message
PointSource is currently offline  PointSource
Thanks for tossing in a reply, GM! Of course, other Q's follow:
Does lower CR equal lower efficiency? Will directivity collapse sooner (without a diffractive throat geometry), resulting in a lower HF cutoff? Could that be why the MSL-4 uses such a low crossover point? I had the idea to mount a midbass driver (or two) in the aforementioned fashion, then affix some kind of throat or smoothing guide to the front of the driver. No rear chamber access panel, no double-walled horns! Then, I'd coax the HF horn in the midbass mouth. Have any experience in that direction?
Previous Topic: Say Charlie; Have you changed your speaker set-up ?
Next Topic: New single driver
Current Time: Sat Oct 17 13:26:19 CDT 2026
