Home » Audio » Speaker » Really Front-Loaded
Re: Really Front-Loaded [message #18913 is a reply to message #18912] Fri, 15 September 2006 08:32 Go to previous messageGo to previous message
GM is currently offline  GM
Greets!
Most of the ~fullrange driver or tweeter WGs I've built have been this way since I didn't want any real throat pressure. BTW, a horn's or WG's throat (St) is the small end regardless of how big it is in relation to the driver's effective piston area (Sd). It just means that the compression ratio (CR) is < 1.0 when Sd is < St, so if a low CR works in your app, then it will work fine on a midbass too.
GM
Previous Topic: Say Charlie; Have you changed your speaker set-up ?
Next Topic: New single driver
Current Time: Sat Oct 17 12:05:33 CDT 2026
