Home » Audio » Speaker » Say Charlie; Have you changed your speaker set-up ?
Re: Say Charlie; Have you changed your speaker set-up ? [message #18895 is a reply to message #18894] Fri, 08 September 2006 23:28 Go to previous messageGo to previous message
I only wish. Really, when using "single" drivers (like Lowther and Fostex) crossing over at around 100 Hz seems to work well. Probably "as low as you can go" is the right answer.
The problem, of course, is how to afford a compression driver (not to mention the horn) that'll go that low. The obvious solution is Wayne's (or for that matter many people's) approach of going with a conventional dynamic driver in some approximation of a conical horn. But it just doesn't appeal to me - probably because I barely have a grip on even a semblance of sanity.
Previous Topic: B&C Drivers
Next Topic: Really Front-Loaded
Current Time: Sat Oct 17 10:47:32 CDT 2026
