Home » Audio » Speaker » Heavy-cones verses light-cones in basshorns
It seems that the problem is the rear chamber [message #18876 is a reply to message #18875] Tue, 29 August 2006 03:04 Go to previous messageGo to previous message
While in theory you can tune the Fh it seems that you're always up against it on the rear chamber volume. You usually can barely fit the driver in the space, so if you need to raise the Fh you're kind of SOL.
If you're building a tightly folded horn like the LAB horn it seems that Fs really dictates the feasibility of physically constructing the thing. Whenever I play with Hornresp I always get backed into a rear chamber volume that won't accomodate the driver.
Previous Topic: Time delay revisited
Next Topic: Finally the x-over is hooked up
Current Time: Fri Nov 06 03:21:58 CST 2026
