Home » Audio » Speaker » Any opinions on these cheap waveguides?
Re: Any opinions on these cheap waveguides? [message #18855 is a reply to message #18852] Fri, 25 August 2006 14:06 Go to previous messageGo to previous message
zobsky is currently offline  zobsky
I picked up one a few months ago, driven by an eminence PSD2002 compression driver. Not bad, .. a bit "croaky" sounding down at the 1200 - 1600 Hz range, I'm not sure if its the horn or the driver's fault, (I don't really have basis for comparision) otherwise okay crossed over higher though I'm guessing any constant directivity built into it might de-emphasise the treble.
Previous Topic: Lower the crossover, the wider the sound stage?
Next Topic: Jordan Drivers
Current Time: Sat Oct 31 06:00:22 CDT 2026
