Home » Audio » Speaker » Conical Confusion
Re: Constant Directivity [message #18826 is a reply to message #18825] Fri, 18 August 2006 01:10 Go to previous messageGo to previous message
Well, a lot of what you said is general and not specific enough to really analyze. But there are a few concrete facts you can get a hold of.
If a horn is short, it will not load down to as low a frequency as a longer horn of the same shape. If its mouth area is small, then it won't have as good pattern control as a larger horn.
Beaming is another name for collapsing directivity and it occurs when a direct radiator becomes directional because of path length differences between points along its cross-section and listening points out in the environment. It occurs in a curved wall horn because wall angle gets narrower further down the throat.
I might suggest for you to study horn theory and learn how things work. The concepts are pretty simple so you can pick it up pretty quickly.
Previous Topic: Merit of Mini Desktop Array?
Next Topic: Here's an interesting experiment
Current Time: Fri Oct 30 23:28:11 CDT 2026
