Home » Audio » Speaker » Need help with room placement
Put your left toe-in....... [message #18775 is a reply to message #18774] Wed, 07 June 2006 16:27 Go to previous messageGo to previous message
Have you tried toe-in? Focus the speakers to cross several feet (5' or so) in front of your listening position and then move several degrees to a toe-out position. You should find a position where the depth/imaging/soundstage comes together. Also, are your speakers along a long or short wall? Try the other wall just to see if there is a difference.
I don't have the Cardas site at hand, but look on their site for some good info on speaker placement, if you have not already.....Best regards, Colin
Previous Topic: Tweeter or Super-tweeter
Next Topic: Xover and line array
Current Time: Fri Nov 06 05:49:14 CST 2026
