Home » Audio » Speaker » Throat size for woofer
Re: Throat size for woofer [message #18754 is a reply to message #18734] Tue, 30 May 2006 19:00 Go to previous message
DMoore is currently offline  DMoore
The old-school rule-of-thumb was a 2:1 ratio (available cone to throat opening size) or about 70% maximum of the available cone area.
Modern calculations like Don Keele's workk use a variety of T/S specs to derive the size for maximum EFFICIENCY for a particular driver IN A GIVEN HORN. The throat size in turn effects the length of the horn.
Without specifics, in general, if you are indeed talking about an Altec A7-ish horn, try 8 or 9" wide for a 15" driver suitable for horn loading. It also depends on the horn itself, however, for very short (14" long) straight horns (A7) with an Fc of 80Hz, 9" is right in the ball park. Again, it DEPENDS!
There are exeptions of course, most of the B&W drivers would be most efficient with smaller throat openings, etc. Download D.B Keele's T/S Horn design paper from his website and do the math manually. It's somewhat tedious, but it's fairly simple to do.
DM
Previous Topic: Driver alignment?
Next Topic: Garage Sales Find
Current Time: Sun Nov 08 12:48:08 CST 2026
