Home » Audio » Speaker » Experience with BMS 4592 ND (16 Ohm)? A few questions - Bill M.?
Re: Experience with BMS 4592 ND (16 Ohm)? A few questions - Bill M.? [message #18657 is a reply to message #18656] Mon, 27 March 2006 19:31 Go to previous messageGo to previous message
DMoore is currently offline  DMoore
Peter, I cannot speak to the neodium version (4592) but I can about the 4590. The overall system Z for the combination mid and tweeter is 10 Ohms.
Complex impedance of the two halves of the BMS coaxial driver (mid and tweeter):
The midrange is 10.4 Ohms at a 39 degree phase impedance, equivalent to 13.5 Ohms in parallel with 0.44 mHy.
The tweeter plot is 7.54 Ohms at a 7.55 degree phase impedance, equivalent to 7.54 Ohms in series with 26 uHy.
The 6300Hz is recommended by BMS because that is where a VERY slight peak appears in the frequency response. I chose 6K for my crossover point.
The tweeter sensitivity is seemingly just fine straight up with the mid, HOWEVER, I chose to attenuate both mid and tweeter frequencies (prior to "splitting" them up)with the same autoformer, so I have a separate tweeter crossover AFTER the attenuation.
The tweeter runs "straight" with the midrange driver once that level is set. The tweeter is not the problem, it's the midrange!
Dana M.
Previous Topic: l-acoustics mtd 115a reliability
Next Topic: Is calculations of L-pads based on "nominal impedance" or Re?
Current Time: Tue Nov 03 09:06:09 CST 2026
