Home » Audio » Speaker » Experience with BMS 4592 ND (16 Ohm)? A few questions - Bill M.?
Experience with BMS 4592 ND (16 Ohm)? A few questions - Bill M.? [message #18656] Thu, 23 March 2006 13:06 Go to previous message
Peter K is currently offline  Peter K
Hi,
I would really like to hear from people who has direct experience with the BMS 4592 ND (16 Ohm version). I do not have access to measuring equipment, so I have a few questions that I hope someone would answer:
1. Does the BMS “mid” have a higher sensitivity than the BMS “tweeter” section and if “yes”, then how many dB’s in difference?
2. Where do you place the crossover between the mid and the high section? (I know that BMS recommends 6,300 Hz, but I have also heard that some people have had difficulties making the two sections “reach” each other.)
3. What is the impedance of the BMS “tweeter” at this crossover point?
Thanks a lot!
Regards
Peter
Previous Topic: l-acoustics mtd 115a reliability
Next Topic: Is calculations of L-pads based on "nominal impedance" or Re?
Current Time: Tue Nov 03 10:20:43 CST 2026
