Home » Audio » Speaker » Sim help?
Hornresp [message #18642 is a reply to message #18640] Mon, 06 March 2006 15:03 Go to previous messageGo to previous message
Do you have Hornresp? If not, grab a copy. Entering the electro-mechanical parameters is a snap, just click on the fields in the lower area of the screen and type them in. You can even double click these fields and the program will prompt you for T/S specs, which it will then convert to force/mass/compliance values. The rest of the data entry is equally simple, just enter length and area and front and rear chamber volume. If you get confused, I'll send you one of my data files as a starting reference. You can always write a post here if you get stuck.
Previous Topic: What is the optimal frequency range for a single driver to reproduce?
Next Topic: Raw Acoustics Omega's
Current Time: Fri Nov 13 06:29:19 CST 2026
