Home » Audio » Speaker » Time Alignment - Horn/Compression & Woofer
Re: Time Alignment - Horn/Compression & Woofer [message #18557 is a reply to message #18545] Fri, 17 February 2006 14:50 Go to previous message
It is pretty important to get the crossover right. And don't forget that the LP filter for the woofer has a delay so that puts the woofer back a few inches. In my speakers the woofer and compression driver have just about the exact same delay to the far field even though the compression driver is several inches further back than the woofer.
Previous Topic: Full range drivers in line array?
Next Topic: Shorting rings - Improve something else besides 2HD and Le?
Current Time: Fri Oct 16 14:06:09 CDT 2026
