Home » Audio » Speaker » Time Alignment - Horn/Compression & Woofer
Time Alignment - Horn/Compression & Woofer [message #18545] Sun, 12 February 2006 19:20 Go to previous message
jshoc is currently offline  jshoc
Is time aligning a compression driver with horn flare and a woofer important?
For example, if the diaphram of a compression drive was aligned with a voicecoil of the woofer, the horn flare in my case, JBL 2385a, would be projecting out about 6" from the woofer.
What am I missing?
Jim
Previous Topic: Full range drivers in line array?
Next Topic: Shorting rings - Improve something else besides 2HD and Le?
Current Time: Fri Oct 16 14:05:53 CDT 2026
