Home » Audio » Speaker » Updated the crossovers on my K-orns to spec
Parameter shifts [message #18408 is a reply to message #18406] Thu, 12 January 2006 12:21 Go to previous messageGo to previous message
There are changes in electro-mechanical parameters even in a single device at different operating levels. And there is a shift over time. I prefer to use alignments that are relatively insensitive to these shifts, basically systems with a wide tolerance. You can model a system at various operating points to see how it will act, and then if industrious enough, measure a physical model at several power levels to see if it performs as expected. I think a system should be designed to allow for pretty wide shifts in driver parameters, because that's what it will encounter. A side benefit of this is that small tolerance changes in component production runs won't matter so much.
Previous Topic: Ciare HX-201 10" wideband?
Next Topic: Commercial Line Arrays?
Current Time: Sat Nov 28 18:07:47 CST 2026
