Home » Audio » Speaker » Updated the crossovers on my K-orns to spec
Re: Updated the crossovers on my K-orns to spec [message #18378 is a reply to message #18377] Fri, 06 January 2006 11:06 Go to previous messageGo to previous message
HI John,
HAppy New year to you!
I think if you are using tube amps, then these perform differently enough that one should specify what they were voiced. I believe most solid state amps are soundless, and hence it doesn;t really amtter what you "voice them with".
The Brook was a push pull 2a3 if I remember. THe one I use is a SE 2a3 amp. I don't believe overall amps add too much of a sonic signature, as long as they are well executed. But they are fun hardware to play with! and sometimes good tube amps add pleasant distortions! I have a lot of tube amps and love them. They do somehow make the music sound more involving than solid state. probably by blunting out harshness.
-akhilesh
Previous Topic: Ciare HX-201 10" wideband?
Next Topic: Commercial Line Arrays?
Current Time: Sat Nov 28 18:07:44 CST 2026
