Home » Audio » General » Visit to Spkrman57's house (pic)
Re: And my 2¢ more [message #1837 is a reply to message #1836] Sun, 29 May 2005 13:48 Go to previous messageGo to previous message
Too many variables to know what's up with your particular setup, and that was precisely my point. Different drivers will act differently, both in cabinet tuning and interaction with the horn and crossover. What works with your drivers may or may not work when other models are used.
If you're running a second-order on the woofer, the output from the crossover measured across the woofer voice coil probably has a significant peak somewhere near the crossover point. Look at pages 14 and 15 of this crossover lab document to see what I mean.
If the driver and horn are falling off about the same place, then crossover peaking may help boost the top end, I suppose. That would make summing through the crossover difficult to predict, so the only way you'd know is to check it and see. This is all very implementation specific, and that was the point I wanted to make.
Previous Topic: Sprkman57 Got Me
Next Topic: The latest FM Tuner Shootout review is up
Current Time: Fri Oct 16 15:28:53 CDT 2026
