Home » Audio » Speaker » Why phase reversal Hornresp
You are absolutely correct [message #18332 is a reply to message #18323] Mon, 19 December 2005 07:32 Go to previous messageGo to previous message
It is impossible to have a phase lead at LF - it must go to zero as the frequency goes to zero or something is wrong.
In this case the horn equations - Websters - are wrong and predict some things athat are ficticiuos - like "cutoff" - doesn't happen in reality. I can't say for sure that this is the problem, but I can say for sure that anything derived from Webster's equation is wrong.
Problem is that Websters EQ should become more accurate at very LF, but if the calculations below "cuoff" are not done properly you could get the result that you see.
Previous Topic: Ping Earl Geddees!
Next Topic: Zaph Audio Seas L18 / Seas 27TBFGC
Current Time: Mon Nov 02 10:02:19 CST 2026
