Home » Audio » Speaker » Earl - Which sub do you use?
Not the way that I would do it. [message #18325 is a reply to message #18324] Sat, 10 December 2005 09:56 Go to previous messageGo to previous message
I don't understand your 3 passive radiators - why would you want to do that?
We used a 10" driver, the same cone area in a stamped metal basket with a 2:1 area ratio. The cost of this later piece was only a fraction of the driver - why would it be more? The cost in a driver is in the motor structure, eliminate that and the cost should only be a fraction of the original speaker. Then we used two of these levers. Result; +6 dB more output at far less cost than two drivers with motors. A single lever would have reduced this cost further, but we liked the packaging options of two better.
I think that you calcs have some problems.
Previous Topic: Woofer choice and attenuation
Next Topic: Focal 5K013L array?
Current Time: Thu Nov 26 10:40:20 CST 2026
