Home » Audio » Speaker » Earl - Which sub do you use?
Levers and multiple subs [message #18319 is a reply to message #18314] Thu, 08 December 2005 12:50 Go to previous messageGo to previous message
Rapid is currently offline  Rapid
Earl,
Sounds interesting about those levers. Do you get 6dB for the whole frequencyrange? I downloaded your software so I've seen what a lever looks like now (pictures are easier to understand). The frontlever looks like a bandpass sub but instead of a port it's got two passive radiators which are connected "in series", where the second has twice the area of the first. The other option is to build a rear lever which looks like a bassreflex but the port is changed into the lever I wrote about above. Right?
Wouldn't it be possible to build the lever with 3 passive radiators (two at the second stage)? What's the problem with using a large ratio of the radiating areas?
Also, I wonder about multiple subs. I think I've read somewhere that the more subs you scatter around the room, the flatter bass you'll get. Is this true?
/Mattias
Previous Topic: Woofer choice and attenuation
Next Topic: Focal 5K013L array?
Current Time: Thu Nov 26 10:40:18 CST 2026
