Home » Audio » Speaker » Earl - Which sub do you use?
Re: The "T" word [message #18316 is a reply to message #18315] Wed, 07 December 2005 07:22 Go to previous messageGo to previous message
Ah yes - got caught - almost! - on that one. The sound was tweaked but only AFTER I had taken several measurements and knew what the situation was. But really, the very low end in a room, say < 100 Hz. is so hard to measure, so completely mixed up with modal patterns that "by ear" actually does work. One should take measurements, but these are never as complete as I would like and then tweak by ear within some contraints of what the measurements say.
I tweak, we all tweak in that I do use tone controls - typicaly -1 dB trebble and + 1 or 2 dB bass. The tweeaking that I was refereing to above was in setting the LFE channel level since this is hard to measure.
Previous Topic: Woofer choice and attenuation
Next Topic: Focal 5K013L array?
Current Time: Thu Nov 26 10:40:15 CST 2026
