Home » Audio » Speaker » Earl - Which sub do you use?
Subwoofers [message #18313 is a reply to message #18312] Mon, 05 December 2005 12:55 Go to previous messageGo to previous message
Rapid is currently offline  Rapid
Hi Earl!
You wrote,
"and thus has its output about five feet in the air - intentional to get it away from the floor."
Sounds like a good idea. Is the sub placed five feet from the walls as well to get less room gain? Might be good to do if you have space or?
Isn't fs of B&C speakers too high to be used as subwoofers? How come you're not using for example Peerless XLS12, Eminence LAB12 or NHT1259?
/Mattias
Previous Topic: Woofer choice and attenuation
Next Topic: Focal 5K013L array?
Current Time: Thu Nov 26 10:41:40 CST 2026
