Home » Audio » Speaker » Folded horns with curves, about 60 – 500 Hz
Re: Folded horns 70 – 500 Hz [message #18295 is a reply to message #18294] Tue, 22 November 2005 07:21 Go to previous messageGo to previous message
Yes, I can send you some plans. But beyond that, it's probably better to take this discussion to the π Speakers forum or leave it as a general discussion about horn theory.
What I would propose is a simple conical horn. The bandwidth you require is mostly midrange, so you might consider a higher crossover point which allows a smaller horn. Naturally, deeper extension will require a larger horn. If you plan to use subs underneath, you could raise your midrange horn crossover point an octave or so, which would make its size requirements much smaller. Then you could go with a straight horn, which is about as simple and pure as it gets.
Previous Topic: Mounting Woofer
Next Topic: what are power extremes/ or nominal power to be....
Current Time: Mon Nov 02 11:07:55 CST 2026
