Home » Audio » Speaker » Mounting Woofer
Re: Mounting Woofer - I did this [message #18284 is a reply to message #18277] Fri, 18 November 2005 04:40 Go to previous messageGo to previous message
roland is currently offline  roland
hmmm and thanks - not sure I get it but:
I glued the ring to the back of the baffle before I put the cabs together.
The driver will be mounted with T-nuts / lock-nuts (or whatever you call them ????? ) so removing the driver is not an issue later.
I hope this helps.
Roland
Previous Topic: Acoustat 1+1 bias voltage idea
Next Topic: Folded horns with curves, about 60 – 500 Hz
Current Time: Mon Nov 02 10:04:10 CST 2026
