Home » Audio » Speaker » Mounting Woofer
Next Question... [message #18255 is a reply to message #18254] Thu, 10 November 2005 16:46 Go to previous messageGo to previous message
As I plan the layout of the front baffle, I'm worried that there isn't enough room. I've thought to put the horn on top, which is fine with me and allows for easy experimenting down the line. At any rate, the baffle is 17.75 x 26.5, overall box is 1.5" taller and wider. I need to also accomodate two 4" ports. I can cram all this on the front, but wondering if that is the smartest idea. Also, is there a minimum distance from the port to the woofer? If I put the horn on top, how close to it should I try to mount the woofer?
Thanks!!
Previous Topic: Acoustat 1+1 bias voltage idea
Next Topic: Folded horns with curves, about 60 – 500 Hz
Current Time: Mon Nov 02 10:02:38 CST 2026
