Home » Audio » Speaker » Anyone Familiar with the Onken Cabinet Alignment?
Re: Anyone Familiar with the Onken Cabinet Alignment? [message #18237 is a reply to message #18236] Fri, 04 November 2005 19:28 Go to previous messageGo to previous message
GM is currently offline  GM
Greets!
The M19 has a classic Altec alignment, peaking around 50 Hz with the -8B, and requires the room to fill in the rest if need be, while the Onken peaks lower based on a percentage of its (Fs/Qts) spec to help the driver above Fs where it runs out of excursion, but rolls off at a steeper rate, so it just depends on the room, speaker location and how much bottom end you need.
GM
Previous Topic: Needed power to drive Jordan JX92S TL's
Next Topic: RE: mounting woofer
Current Time: Mon Nov 02 11:06:53 CST 2026
