Home » Audio » Speaker » Help w/New Project
Re: Help w/New Project [message #18202 is a reply to message #18191] Fri, 28 October 2005 08:33 Go to previous messageGo to previous message
HI Steve,
I just finished an Altec based project. I have a large living room too. My wife actually likes the system, and it has a large sound stage, good imaging, and great eff.
I used an Altec 511b horn with 808a alnico drivers from 1500 Hz up
Altec 515B driver (15" alnico) in a designed bass reflex box (yes, I had to get rid of the A7 horn/bass reflex enclosure, and build a pure BR) from 90 HZ upto 1500 HZ
and a single Hsu VTF 3 sub from 25-90 HZ.
The whole thing is actively crossed, and I am also using parametric EQ. My amplification is Luxman 4 channel solid state for the mids and highs (25 watt oer channel).
The overall sound is super clean and detailed, very satisfying.
THe cost of this is around $2k-$3k, depending on your ability to scrounge parts, etc. But it's worth it! I can't imagine a commercial system that sounds anything like it. For a large room, it's a good match. Added bonus, movies sound AWESOME on it, not surprising since it's the guts of a VOTT system!
-akhilesh
Previous Topic: scan subwoofer
Next Topic: Advice on choosing best dsp to be programable for use with acoustical arrays
Current Time: Fri Nov 27 09:31:32 CST 2026
