Home » Audio » Speaker » Help w/New Project
Re: Help w/New Project [message #18195 is a reply to message #18194] Thu, 27 October 2005 18:38 Go to previous messageGo to previous message
Well; when you say reference that takes in a lot of territory.
My very humble opinion. If imaging is the thing you are after you need a smaller woofer two way. It seems to me that as you get higher up in size you gain prescence and lose image. I prefer prescence but that is just me; I can see your point also.
The best sounding audio speaker I have ever heard is a di-pole; something like what you did with your Dyna A25's by opening the box. Why not look at Seigfrieds site and see what you think. Since you are O'Kay with using a subwoofer than that might be ticket for you.
But you must use very high quality drivers to get the real benefit; and they are expensive.
Previous Topic: scan subwoofer
Next Topic: Advice on choosing best dsp to be programable for use with acoustical arrays
Current Time: Wed Nov 04 07:03:39 CST 2026
