Home » Audio » Speaker » Horn Mouth Diffraction
Re: Horn Mouth Diffraction [message #18166 is a reply to message #18163] Thu, 06 October 2005 18:31 Go to previous messageGo to previous message
Martin is currently offline  Martin
M,
Looking at the EDGE again I think I was in error. My MathCad worksheets use the same basic math as the EDGE but can handle both rectangular and circular sources and baffles. So modelling a round or rectanguler horn mouth and baffle is easily done. I don't think the EDGE will do those combinations. I used the EDGE as a double check of my algorithm using sample problems.
As far as rounded edges on baffles, I do not believe that exact modelling of this is needed. There are two effects from the baffle, the baffle step as the sound radiated transitions from 4 pi to 2 pi and the sound "scattering" at the edge itself. The second effect produces small wiggles in the SPL plot. I do not believe that these small wiggles are as significant as room effects or the baffle step response. Maybe this is because I use full range drivers that are starting to beam at these same frequencies so the impact of the edge sharpness/radius is minimal.
Thanks for the offer of help with the horn worksheets. At this time I am pursuing a design and test of my own and have decided to hold onto the worksheets and the test results until I decide what I want to make available.
Martin
Previous Topic: Advice on choosing best dsp to be programable for use with acoustical arrays
Next Topic: Thoughts for Steve's Speaker Plan
Current Time: Fri Nov 06 03:21:34 CST 2026
