Home » Audio » Speaker » Predicting The Effects Of Grille Cloth ???
Thin Silk [message #18142 is a reply to message #18138] Thu, 08 September 2005 22:54 Go to previous messageGo to previous message
GeneB is currently offline  GeneB
I've settled on thin silk. About $12/yard. If you are artistic you can use water colors to add a fashon statement. If not, buy pre-dyed.
I build two curved aluminum rods, left/right, sew a loop on the end of the slik that slides onto the rods, and tenson the silk by pushing the ends of the Al rod into holes on the front baffle. Looks a little like the Revels.
Previous Topic: revisiting the Delta 12LF
Next Topic: Playing w/Horns
Current Time: Fri Nov 13 07:40:51 CST 2026
