Home » Audio » Speaker » Predicting The Effects Of Grille Cloth ???
Re: Predicting The Effects Of Grille Cloth ??? [message #18139 is a reply to message #18138] Wed, 31 August 2005 16:09 Go to previous messageGo to previous message
There may be a published absorption coefficient or sabins figure for the material. If so, using that and its position, you can predict what effect it will have. You could also use something like Speaker Workshop to measure the speaker with the grille on and off, and compare the difference.
Previous Topic: revisiting the Delta 12LF
Next Topic: Playing w/Horns
Current Time: Fri Nov 13 07:41:09 CST 2026
