Home » Audio » Speaker » 80-100hz corner horn??
Re: 80-100hz corner horn?? [message #18130 is a reply to message #18122] Fri, 26 August 2005 23:20 Go to previous messageGo to previous message
DanTheMan is currently offline  DanTheMan
It should be about 90-100 cms deep and open up at 2100-2300cms I believe. That should do it according to the hornresponse program. Seems like it might be hard to find a woofer that will give you reallysmooth (mid)bass response though. I'm still debating wether to try one or use a pi mid(it seems much easier to get a smooth low-end with that.
Sorry, that's the best I can give you.
Previous Topic: Port Calculation
Next Topic: Mac Horn Programs?
Current Time: Mon Nov 16 17:30:05 CST 2026
