Home » Audio » Speaker » Filling behind the horn of the A7/828 cabinet
Re: Filling behind the horn of the A7/828 cabinet [message #18090 is a reply to message #18089] Sun, 07 August 2005 02:51 Go to previous messageGo to previous message
I've had good experience with closed cell foam. It expands to fill in the area and preloads the panels. Forms a solid mass and doesn't weigh much at all. The one downside is it's easy to overfill, which then can over expand and burst panels. So you have to be careful to consider the expansion when using the stuff, and don't fill the area, let the expansion fill the space.
Previous Topic: Conical front horn
Next Topic: need data on gauss hf 4000
Current Time: Mon Nov 02 11:07:43 CST 2026
