Home » Audio » Speaker » sensitivity: conversion of units
Re: sensitivity: conversion of units [message #17954 is a reply to message #17952] Wed, 08 June 2005 13:31 Go to previous messageGo to previous message
GM is currently offline  GM
Greets!
I've seen various values used for half space pressure, from 112 -112.2 dB/m, though 112 seems to be the most common. FWIW, I calc'd it at 112.018, so rounding it off to 112 and 1 % eff.........
dBv = ~112+10*(log10(0.01)) = ~92 dB/~2.828V/m
Since 1 W = E^2/R = ~2.828^2/8 = 1, then dBa = ~92 dB/W/m for 8 ohm nominal loads.
To convert other nominal resistances (R) to dBa, add 10*log10(R/8) to the dBv, so if the above is a nominal 4 or 16 ohms, then dBa = ~89 or 95 dB/W/m.
GM
Previous Topic: Linus Array
Next Topic: Electrostatic Speakers
Current Time: Thu Nov 19 15:09:29 CST 2026
