Home » Audio » General » Attenuate amp inputs
Re: Attenuate amp inputs [message #1795 is a reply to message #1791] Wed, 25 May 2005 11:57 Go to previous messageGo to previous message
You might get an assortment of resistor values up to 150k and an assortment of capacitor values in the pF range. You can bypass the 150k series resistor with a capacitor and the size will determine where treble boost starts. But that won't set the amount of boost, only where it starts. You can reduce the amount by splitting the series resistance into two parts, and bypasing them separately. One resistor might have no bypass or it might have a different value than the other. This just gives you some flexibility, that's all.
Previous Topic: Warning: Dangerous Territory - A Cable Question
Next Topic: Breaking ground loop hum caused by satellite dish...
Current Time: Fri Nov 13 21:24:38 CST 2026
