Home » Audio » Speaker » A7s upstairs and almost ready to go
Re: A7s upstairs and almost ready to go [message #17908 is a reply to message #17907] Fri, 03 June 2005 20:54 Go to previous messageGo to previous message
GM is currently offline  GM
Greets!
Smaller horn/higher XO makes it worse until you find the right offset. Turning the cab upside down and putting the horn in the port helps somewhat, but makes finding the right offset more of a PIA if you don't make an adjustable sled for it and the sound is compromised in other ways, though they can be delt with.
GM
Previous Topic: 150 Hz Edgar horns - What to do? (pic)
Next Topic: Arry port lengths
Current Time: Wed Nov 04 02:13:55 CST 2026
