Home » Audio » Speaker » OS waveguides
Re: OS waveguides [message #17903 is a reply to message #17896] Thu, 02 June 2005 22:36 Go to previous messageGo to previous message
I'm sure Earl will chime in, but I wanted to interject one thing that he and I talked about in this regard. Most agree that the phase plug should be matched to the horn. Instead, there are a handful of common shapes installed in most compression drivers, such as those using radial or annular ring slits. It would be better to have a variety of interchangeable phase plugs for different applications. This doesn't address your post; Earl would be best to discuss his papers. But it is germane in the context of a "properly designed phase plug."
Previous Topic: epiphany model 6-6 /12-12
Next Topic: Linus Array
Current Time: Sun Oct 18 17:21:51 CDT 2026
