Home » Audio » Speaker » Are jbl 2440's easy to open and clean
Re: Are jbl 2440's easy to open and clean [message #17766 is a reply to message #17760] Tue, 26 April 2005 07:42 Go to previous messageGo to previous message
To add to what Wayne says, be carefull re-inserting the diaghram back into the magnet assembly, the voice coil formers and coils are usually more fragile than what they are on a normal speaker. Also make sure your voice coil gap is clean from debris otherwise your going to get buzzes, rattles, scrapeing coils etc.. If I remember right the JBL's I think have alignment pins make sure those line up.
HTH
Bill W.
Previous Topic: Line array design software?
Next Topic: Ping Akhilesh
Current Time: Fri Nov 06 02:03:52 CST 2026
