Home » Audio » Speaker » manipulation of horn calculation
Re: manipulation of horn calculation [message #17748 is a reply to message #17747] Tue, 19 April 2005 14:32 Go to previous messageGo to previous message
Placing a horn near a boundary acts similarly to a mirror, so for example, half-space acts like twice the cross-section area of a horn in freespace. Once you get to eighth-space, you also gain length because the expansion from the apex of a corner forms a conical horn, all by itself. The corner's expansion adds length and area because it is quite literally a horn flare in toto. Grab a copy of McBean's Hornresp program and run some horn simulations because that will give you a good feel for the behavior of different horn flares in different spatial conditions.
Previous Topic: Line Array Tweeter Question
Next Topic: Internal Damping Material
Current Time: Fri Nov 20 05:19:16 CST 2026
