Home » Audio » Speaker » Anyone familiar with Smith Horns?
Re: 2 questions that would clarify our thinking... [message #17746 is a reply to message #17745] Sun, 17 April 2005 23:09 Go to previous messageGo to previous message
A sound source that is smaller than a quarter wavelength is basically a point source.
Anything that causes multiple sound sources a half wavelength apart or more will cause interference. This can be two adjacent drivers in a multi-way speaker, in the overlap region where both drivers are playing. It can be two drivers in an array. It can be two loudspeakers, not in an array but placed where this occurs. It can be sound produced from a single driver coming from two edges of the cone. Or it can be from a single source and its reflection from a boundary or another outside object.
Where there is cancellation at a specific frequency, it causes a notch in response. It's easy to see on a response graph, having the tell-tale notched downward spike. Naturally, what most speaker manufacturers do is to strive to minimize these kinds of interactions. But another approach is sometimes taken, and that is to make the interactions so dense that they tend to average out. If there are lots of nulls spaced close together, that's called dense interference. If dense enough, it sort of averages the sound field.
Previous Topic: Anyone here use the little .75 neo PE tweeter?
Next Topic: free download bass horn
Current Time: Tue Nov 03 13:40:04 CST 2026
