Home » Audio » Speaker » Anyone familiar with Smith Horns?
Re: I know what I've read.... [message #17736 is a reply to message #17735] Fri, 15 April 2005 07:48 Go to previous messageGo to previous message
You know, this thing about directivity and imaging still has me confused. My understanding is that more directivity means less sidewall reflections, which in turn produces better imaging. However, highly directive sources tend to produce a very small sweetspot. Diffused sources create more reflections which hurts imaging. But if the room is good, it shouldn't be a problems, and can in fact produce a larger sweetspot, provided frequency response is uniform. Am I close?
Anyhow, looking at the diagrams on audioheritage, it seems pretty easy and cheap to mock one of these horns up. The only difficulty is getting a set of throat adaptors. If I can get a pair of adaptors inexpensively, I'll give these horns a try.
Gar.
Previous Topic: Anyone here use the little .75 neo PE tweeter?
Next Topic: free download bass horn
Current Time: Tue Nov 03 13:40:05 CST 2026
