Home » Audio » Speaker » Altec 902 / Edgarhorns: compensation experiments
Wish i understood everthing you said... [message #17691 is a reply to message #17682] Tue, 29 March 2005 12:32 Go to previous messageGo to previous message
spkrman57
Wayne,
The "DI" factor loses me. I know I just tried out my 1st JBL compression driver(2426J). I used the 4 Pi-pro figures(15 ohm shunt and 33 ohm series/.33 ufd cap). I also used .68 ufd bypass caps on the PE 1.6 khz hi-pass crossover.
So far I think the caps are still new and not smoothed out(less than 2 hrs time on them). I find the JBL to be rather bright in the upper midrange/lower treble area used on the Martinelli horn. I know that the 2426J is a 16 ohm driver, but I have used Altec 8 ohm and 16 ohm drivers without changing up the crossover with little difference of sound.
I think the JBL with titanium diaphram is more brittle sounding than the aluminum of the Altec drivers I have used. I set up the crossover this time with easy "connect/disconnect" terminals to swap out the horns quickly.
I have my Altec 902B on my 650hz Edgar horn and will be trying it out tonight. I think the JBL needs less HF compensation than the Altec 1" drivers.
Ron
Previous Topic: PHY-HP - Know anything about these?
Next Topic: Does anybody here know how to add and subtract?
Current Time: Wed Nov 04 08:06:02 CST 2026
